wall cabinet fix
10 Nov 2009
Looking to rehang a kitchen wall cabinet that came away from wall bringing the old rawl plugs with it. Looking for advice on
1. Can I fill the holes with pollyfiller, allow to dry out redrill and fit new rawl plugs?
2. If this will be strong enough how long do I need to let the filler dry given the depth on the holes?
3. How do I get the filler right down into the holes without air pockets?
Thanks in advance for any advice.
Jambobean
heeelllooo and welcome ambobean :D :D :D
assuming its brick and plaster
fill the hole with poly filler no7 masonery bit drill a 2" hole knock in the brown plug below the surface 1/4 inch[6.5mm] then use a 2 1/4" no 8 screw or 4.5mm x55mm
if the screw is more than 3mm from the wall suface [thicker brackets] add the bracket size to the screw length
Can you not relocate the cupboard an inch or two to a new location, or has it got to go back exactly where it is now?
Roughcaster.
Hi
Thanks for advice so far.
The reason I can't resite the cabinet is it has to fit against other cabinets that are still in place. So it would be preferable to put it back exactly where it came from.
Cheers
JB
no no no! Not Polyfilla!
Drill the hole a bit deeper into sound brick so you can use a longer screw
Test that the plasplug will go right into it
remove the dust from the hole with a vacuum cleaner or squirted water
Get a tube of no-more-nails or simlar, push the nozzle deep into the hole so it fills from the back (there must be no air-gap at the end)
push your plasplug deep into the hole so that the no-more-nails bulges out at the surface (you may need to insert the screw a couple of turns to push it in, or tap it lightly with a small hammer)
smooth the NMR with a wet finger
let it set overnight
and it will give you a good strong fixing, the plasplug will not come loose or turn in the hole or pull out. It is important that the plug and screw are mostly in the brick, not the plaster.
This NMR in the hole for plasplugs gives a dependable fixing, and is the best DIY tip I've heard in 20 years.
Just drill existing holes to 70mm and use timber wedges hammered in to replace wall plugs, much more secure than plastic plugs, the cabinet should be screwed to adjacent cupoard so the weight is shared by all the cup'ds fixings.
Just a quick thank you to all who replied. Cupboard up and secure, I used JohnD's advice as it best suited the situation.
Cheers
JB
:) I love a happy ending.
Best new DIY trick I've had in 20 years, that.
Gripfill ideal for it ;) Have done it that way a few times when the masonary drill bit can slip sideway slightly making the hole slightly too big.
If you cannot wait then use injecting chemical fixings or resin fixings (a bit dearer this way), rock hard within 20mins
