Hi guys,
Now , i know this is the building section but im looking at finding some sort of high strength fixings
Anyway, I installed a bathroom suite as a favour for a friend as his grandparents are in there 80's and kept getting stuck in the bath. I installed a walk in shower instead of a bath.
The original walls are paramount plaster board so i installed moisture resistant plasterboard on top and then tilled over this. One wall is a partion to the bedroom, so there is no way I could install the seat on this as it just would take the load. However, the other wall, from what i can remember was again paramount board with either concrete block or breeze block as its the gable end of the house.
The seat came with 5 3inch m8 coach bolts with 5 m10 nylon plugs. I installed these but because i couldnt feel myself drilling into the block, i not happy to let them use it. So i went out and bought some m10 rwal bolts, i drilled out the holes to allow for the extra length (100mm) but still did not fell any resistance from the block. I tried a rawl bolt but it not gripping so i dont think they are long enough
can anyone please tell me what fixings i can use to make sure this is going to take the weight of 2 pensioners.
many thanx in advance
