wall hung toilet height??
Whatever feel right! Easiest way is to measure the height of the/an existing pan.
What are you hanging it on? Don't they usually fit on robust metal supports? Surely they can only be fitted at a fixed height on these supports?
you should have a frame with it that has the concealed cistern on the frame and that should have some holes already there for your pan to be hung from
don't matter if its on a frame or not the frames have quite a wide range on the adjustment height so for a first timer it can be puzzling.
stick around the 400mm height from floor to pan seat height.
What's puzzling about it? Hasn't the OP heard of a thing called a tape measure!!!
its amazing what you can find out on the internet
even where to buy a tape measure.
