Wall Hung Toilet On Wall with Bolts
17 Dec 2010
Hampshire
I want to hang a Villeroy & Boch Omnia Classic Close Coupled WC on a breeze block wall using bolts (and no metal frame). Is it best to hang the toilet on the wall with bolts or should I drill right through the wall and secure the toilet to the wall using nuts and bolts. What bolts should I use? If the bolts go right through the wall, is it also best to put them all through a metal plate on the other side of the wall to spread the pressure? One problem is, that I want to tile the wall on the other side of the cistern. There is a cupboard on the other side of the pan, so nuts and bolts there are not a problem. Can anyone please advise me accordingly. Thanking you in advance.
I want to hang a Villeroy & Boch Omnia Classic Close Coupled WC on a breeze block wall using bolts (and no metal frame). Is it best to hang the toilet on the wall with bolts or should I drill right through the wall and secure the toilet to the wall using nuts and bolts. What bolts should I use? If the bolts go right through the wall, is it also best to put them all through a metal plate on the other side of the wall to spread the pressure? Can anyone please advise me accordingly. Thanking you in advance.
google rawl bolts.
google rawl bolts.
Thank you for that.
