I want to fit a wall hung toilet and would like to use a no touch sensor flush such as.... http://www.roperrhodes.co.uk/product/contactless-dual-flush-sensor
Most of the frame based cisterns include press button flush please which also double up as access points. Like this http://www.builderdepot.co.uk/geberit-duofix-wc-frame-0-82m.html I believe the sensor flush will work with these but just using it instead of the buttons provided. However, with many the button plate appears to double as an access point for future servicing. Therefore if I don't use the buttons, do I need a blank plate to act as an access point? If so where do I get one as I can't find one.
I can' seem to find a wall hung cistern which comes with a sensor flush as standard.
Any suggestions as to the best way to achieve this? This is to be used in a small, narrow 'toilet only' room with the frame at the one end under a window ( needs to be below 1m). I was planning to build a low stud wall to cover the frame with a stone top ledge over the top which could be removed for service.....
