Wall hung vanity plumbing
10 Aug 2006
Cardiff
Planning on fitting one of these but had a plumbing question...
Are these generally only suitable for where the waste and hot/cold feeds are in a stud wall?
I was planning on mounting to a solid wall and running the waste and feed down the wall behind the unit, then boxing them in.
Just wondering if they generally have room behind the drawers for this..
Cheers
Thanks Denso.
You'd think this would be a common problem but online specs rarely show dimensions like this. I'll ask the question.
Yeah thought of that. Walls are engineering brick and bloody hard. Didn't fancy chasing a waste into those walls... Although worst case I guess they'd only need partially recessing.
These units can always be modified (cut) to accept the pipework if they are supplied with a rear service void (some are - some aren't). Only issue there is you will be left with unsightly pipework down the wall and as you say will need boxed in otherwise it would spoil the look and point IMO.
It would look far better if you did
