If you are insulating walls internally does this need to extend underneath the floorboards?
I'm looking at internal wall insulation for some solid wall rooms, and have been reading some threads which indicate that you shouldn't stop at the floor, and that you need to insulate underneath the floorboards to avoid thermal bridging and damp damage to joists.
This seems entirely impractical, as even if you put insulation underneath the floorboards, unless you cut the joists back and then wrap them in insulation they're still going to be exposed to the outside wall.
