Hi
Like many others i've mounted a flat screen on wall and the power lead does not reach socket. As its a hard wired connection, i guess these are my options
- Extension lead (no good as planning on hiding cable with trunking, no room to hide behind tv)
- replace power lead from inside tv (no good as i'm not that capable!)
- Extend the length of lead by joining 2 pieces together (this is the one i'm thinking of doing and is probably easiest to hide).
If i go with the 3rd option - can anybody explain exactly what i must do. I've read that i required a 10 Amp 3 Pin Lead Connector. I'm guessing cut the end of existing plug, wire it to connector. Purchase another power lead (not sure???), cut the plug off that and attach to connector. Join connector.
Any help would be greatly appreciated.
