Wall mountain flush with missing parts
26 Nov 2024
I have an older version of wall-hung toilet with a concealed cistern from victorianplumbling and the latest version from victorian plumbing has different parts. The mounting frame for the flush plate is missing. The dimensions of the white cistern box where the frame for the flush sits needs is 165mm (height) x 175mm (width).
I am struggling to find a flush plate and flush plate mounting frame + buttons that are compatible with the version of the system I have. The latest flush plate on victorian plumbing is a different size.
The flush plate I wanted to use is the Arezzo Brushed Brass Square Button Flush Plate (Part No.: FLSBBS). However, it doesn’t fit the current cistern box and the flush plate mounting frames available for Arezzo compact cisterns don’t match the dimensions of my setup.
I’m looking for a solution to either adapt an existing mounting frame, create a custom one, or find an alternative way to securely install the flush plate. Could you help with a workaround or recommend a way to custom-make a compatible mounting frame?
https://www.victorianplumbing.co.uk...wc-cistern-with-wall-hung-frame-arezzo-toilet
https://www.victorianplumbing.co.uk/arezzo-brushed-brass-square-button-flush-plate
https://www.victorianplumbing.co.uk/flush-plate-mounting-frame-for-arezzo-compact-concealed-cisterns
