Lo
I have a wall mounted gas glow worm condensing boiler professionally installed and on the wall at right angles have a gas hob - the gas hob is not directly under the boiler (but its not far away) there is 250mm to the wall and the boiler overhangs that space
no real choice over location of either - so am planning to box in boiler (instructions say its ok) as concerned about steam from coking going under boiler - I hope to squezze in a 600mm extractor fan over hob though this will make access to boiler tricky
not sure what choice i have but are there any regulations about distance between gas boiler and hob ? the installers knew hob was there
