Can a wall mounted toilet cistern (the cistern doesn't rest on the toilet) be safely affixed to a plasterboard wall?
As long as you can affix it safely then no problem. It doesn't have to be a solid wall.
Being an old dinosaur I would want some wood behind the plasterboard - not a big hole though- just enough to get a bit of roofing batten through. It is a good point about the loading - shear load apparently, but.....
