Hi, I'm having difficulty fitting a curtain cable up in my lounge. I bought a curtain cable, with brackets from ikea to hang some lightweight curtains. But each time I try to hang them the fittings come away from the wall. I've used several different types of plaster plugs now but every time they just pull through. It's obviously not the weight of the drapes, but I think it's because of the tension of the wire cable. The last time I managed to find a concrete lintel above the window, which I was able to drill into and attach two of the brackets. But the left hand one could only go into plasterboard, and again it just pulled through. The plasterboard seems to crumble quite easily you see. It's a new property, so I'm not sure if maybe it's the quality of the materials used, as I don't think it seems too much to ask to expect a lightweight curtain cable to stay up surely?
Any ideas? I would appreciate any advice anybody has. Is there anything I can buy to help the plugs stay secure in plasterboard? Has anyone else experienced similar problems with wire cable curtain rails?
