Doing my hall, stairs and landing, a big job.
Stripped off paper, washed walls and scraped off glue. Filled any damage with Polyfilla and rubbed down with orbital sander. Repaired areas ranging from a small "ding" to longer hairline cracks that I assume have been there for a while. Applied white matt emulsion as a "base" coat to give me a consistent background colour and applied 2 coats of Dulux trade matt emulsion.Walls are plastered, not plasterboard.
Now the problem. When looking at the wall "head on" it looks great. Colour is even and any minor blemishes that I did not repair pretty much disappear. However, at some angles I can clearly see areas that have been filled and sanded, I also suspect that 100% of the old paste did not come off? The areas either appear to be slightly lighter or darker than the surrounding area depending upon the angle that the light falls on the defect. One wall which had no repairs looks great at all angles.
I have tried applying a 3rd coat of emulsion to cover this up with no success.
What can I do to obtain a consistent finish across the whole wall? I spent the best part of a weeks holiday doing the prep so am pretty disappointed right now and at a bit of a loss as to what to do.
Steve
Steve
