I was hoping someone can provide me with a little advise.
Im interested in installing a bathroom TV. In order for me to do that, I will need to remove a section of the tiles and then create a recess in which the a back box is installed (the TV is then mounted onto the back box). The TV will be installed on an external wall, which consists of the standard 100mm block, 100mm cavity and 100mm outer brick.
The installation instructions claim the following recess dimensions for in-wall installation W560 x H390 x D95 (mm), im concerned about the depth, taking into consideration the tile thickness im guessing I will need to around 85 - 90mm into the inner block, which is very close to the full 100mm, a simple slip and I have a 560 x 390 hole.
Would a 560 x 390 hole to the internal block work damage the structural integrity of the wall? (I wonder if the backing box and TV would provide the support required)
btw what tool is recommended to create the recess, a channelling chisel?
