R
ryoc
The tile grout on one wall in my shower was going brown. No cleaner would shift it. I treated myself to a Fein Multimaster and cut out the grout. As the cutter was going through, the grout was coming out wet and brown. Then a couple of tiles came away from the wall. The wall behind the tiles, from the tray to about 5' up, is soaking wet. I have stripped about 24 tiles off and the ply behind is starting to dry. Could the water penetration be due to a bad silicone seal on the tray? It would not draw up that much water would it? It only appears to be wet on one of the walls.
Any advice would be appreciated. The ladies of the house are not impressed that the shower is out of order!
