Wall Strap Placement
27 Jan 2010
Cheshire
Could anyone give me the standard sizes (inc thickness) and spacing for wall straps for the garage part of my development. The garage width is 3.3 x 11 metres which I am putting a 17 degree pitched (gable end) concrete tile roof. I am using 100x50 rafters sitting on a 100x50 wall plate. Any suggestions would be welcome.
UKKiwi
Holding down bent straps are normally spaced 1.8m - 2m and are 5mm x 30mm x 1200mm galvanized mild steel.
Restraint straps (same spec as above but 1500m long) are also spaced at maximum 2m and must cross three joists/rafters with solid noggins between.
