Wall taps to overflow filler tap
11 Apr 2014
HI,
I have two wall mounted taps
(http://www.qssupplies.co.uk/bathroom-furniture-shower-taps/2952.htm)
that will be connecting to an overflow bath filler similar to this one
(http://www.qssupplies.co.uk/bathroom-furniture-shower-taps/77555.htm)
It has a single inlet which means that I need to mix the water before it enters this connection. I am probably being thick(!) but can I just use a standard equal-T as the mixer, or do I need a special block to do the mixing?
If the supplies are at the same pressure then yes, simple T to open outlet OK
if tank-fed hot and mains cold then potential problems, even then probably OK
