Hi all
If a Chimney breast has been removed in the kitchen internally (between a kitchen and living room) in a 1930's semi from ground floor level what thickness should the brick be? Mine are half a brick in size? To put it into perspective I have a disused fire in the living room. If I were to move that away I can see the kitchen plasterboard.
So I have the rsj supporting the from of the breast spanning from wall to wall. One end bearing resting on half brick (running lengthways) the other going into an outside wall.
