Hi folks,
I'm after some advice on wall ties. I've just read a couple of "discussions" on them on here, but they don't answer my specific question.
I am doing a cellar conversion in my 1931 semi. The front (cavity) wall of the cellar is entirely below ground. It is currently buttressed (against the pressure of the soil outside) by a great lump of concrete about 50cm high and about 1.5m deep into the room. A structural engineer is redesigning this for me, basically to be higher and less deep, so as to give (much) more floor space.
This will mean that most of the wall becomes hidden behind a good thickness of concrete and will forever more be inaccessible, to all intents and purposes.
Now the buttress will be on the inside of the cavity wall, and the pressure on the outside - so the wall ties are all that is preventing the wall from collapsing in. Therefore I thought it might be a good idea to have some wall tie work done NOW, on this part of the wall, because it will shortly get a lot harder to do.
To be clear - there is no sign (that I can see, or that builders can see, or that surveyor could see 6 months ago when I bought the house) that there is anything wrong with the existing wall ties.
What do people think about this? Is it a waste of time/money? If I do it, should I have the old ties removed? My thinking was, there's nothing wrong with them - leave them in there and just give extra strength. Also removing them would disturb the wall - no point removing bricks and weakening the wall just for the sake of it. But I may not have considered all the factors.
Thanks!
-Mark
Thanks!
-Mark
