I am papering a feature wall and it finishes on an external corner. What should I do to prevent the paper from peeling back from the edge or being torn? Is there anything I can buy?
Thanks Colette
If the paper has only to stick to an emulsion/plaster base then no special tratment. Unless it's prone to shoulders rubbing past. Or, the edge is covering over a vinyl paper then use a Viny to vinyll border/repair paste along the edge
