Wallpapering around alcove shelving
24 Oct 2014
London
In my Victorian property I have fixed, immovable shelves in two alcoves either side of the chimney breast that I need to wallpaper around with patterned paper (I'm just papering the alcoves, not the chimney breast). How do I paper behind/around the shelves to keep the pattern matching?
You cut the full length required then draw out where the centre thickness of each shelf is positioned in the paper. Cut along these lines and you then simply paste in each intershelf section, trimming off the half-shelf-thickness excess under and over shelf bottom and top.
