Hi trying to hang and pattened paper around corner .corner not straight as i assumed . javascript:emoticon('')
Also what would you use to size the walls and would you do the whole room first or just the wall your working on.Do you leave it to dry or work wet????
Lastly I have a window which is set back so I would like to wall paper the internal walls of the window....sure these have a proper name.But when it come to doing it you end up with either a raw edge on the front top edge as you have cut the paper to fold the side around the edge into the window.
please HHHHHelp
please HHHHHelp
