hi i have a baxi combie 105e boiler
these are the radiator running at the moment 2 of which were not long added to the system
there still seems to be a cold spot in the passage where there is no radiator . but has a front glass door and a window at the top of the stairs
i would like to add a radiator in the passage way will the boiler allow this
cant work out how to calculate boiler to radiator . so any help will be appreciated
i found this also
1. The Baxi Combi 80e or 105e is a fully automatic gas fired wall mounted combination boiler. It is room sealed and fan assisted, and will serve central heating and mains fed domestic hot water.
2. The boiler is set to give a maximum output of 24.0 kW (80e) or 31.0 kW (105e).
these are the radiators used now
1041 x 610 single
1193 x 400 single
1041 x 400 single
1016 x 600 single
635 x 600 single
965 x 609 single
787 x 500 double
1016 x 381 double
thanks ron
i found this also
1041 x 610 single
1193 x 400 single
1041 x 400 single
1016 x 600 single
635 x 600 single
965 x 609 single
787 x 500 double
1016 x 381 double
thanks ron
