Want to change eurocylinder lock but no retaining screw
25 Sep 2016
HI,
I want to change a eurocylinder lock on my multipoint lock PVC door. But i cant find the retaining screw. Can anyone please let me know where i can find it?
Take the face plate off and the screw will be behind that, the cylinder will likely be a 35/35
Thanks, as you said it was behind the face plate.
Think it is 35/35. Right now i can see almost 7-8 mm protruding on the external side and the internal side. To avoid this, i am planning to buy a 30/30. Also i measured from the centre of the retaining screw to the door handle which is 30/30. Hopefully it should fit. Do you think there would be a problem?
