I have just fitted a Nest to my Glow Worm Betacom 24c combi and found that the mechanical timer (the type with pegs that you slide in or out) is playing up. I have put all the pegs to the permanently ON position but the on off switch in the middle of the circle is broken and manages to turn the boiler off occasionally.
I want to disconnect the whole timer but fear that will break cancel heat demand. Is there a way to disconnect it and leave the wiring set for permanent demand?
