Our dishwasher just packed up, and the washing machine is on its last legs, so will be replaced at the same time. I'd like to go integrated for neatness as its a small kitchen. But I'm not sure they'll fit as-is and would like some advice.
Here are a couple of pics of where my appliances currently are (would be replaced like for like.
so a few questions here.
1 - clearance: the worktop is just straight on the wall, no units underneath just the applicances. So there is a batten on the wall giving me only 58cm clearance. Additionally there are some water pipes going a little way behind the washing machine which might make it even tighter. How much clearance do I really need for an integrated unit to be flush with the worktop?
2 - the sink unit: As you can see, the sink unit just ends about 10-15cm short of the worktop where the appliances sit. Its a bit ugly and I'm not sure what should be done here. Would it be best to replace the worktop over the appliances with a deeper one so it lines up with where the sink unit cupboards finish?
3 - end of the run. Next to the dishwasher there is a fairly short end panel. Again, if I go for integrated units, will I need to replace this with a larger one to properly fit the unit door against?
4 - padding. Lastly, the whole width of the gap where the appliances go is about 1350-1400mm, so there would be a gap even after having both appliances fitted. How best to fill this?
thanks for any advice you can offer
