wanted: a sound proof solution
25 Feb 2011
London
hello,
i live on a busy a-road outside my front door and would really love some advice on the best way to dampen the noise. the door currently in place is the original edwardian door with glass pane and there is a pane of glass above it too. it lets in noise, draft and dust.
i would like to achieve the maximum possible noise reduction but make sure that any new exterior door is in keeping with the style of the house i.e. wooden.
do i replace the lot (door and pane) with something bespoke and double glazed that will fit really snugly into the frame. or is secondary glazing inside the hallway a more effective way of blocking the noise? in which case i would keep the original door. or may be some combination of the two, an off-the-shelf front door that i get my builder to fit and some secondary glazing.
hopeful for peace and quiet,
crazyhands
Hi Crazyhands
There's a limit as to how much sound insulation you can get from a door, but here's my take on it. - make sure the perimeter seal is good so yes a snug fit really helps, if you have to have glazing go for double glazed. Generally the heavier the door the better it's performance from a noise point of view. If you go for new check out the manufactuers website and try to get a doorset with a minimum sound reduction index of 30dBRw.
Hope this helps a little
Cheers
Steve
Steve Clow MIOA
http://www.URLremoved.co.uk
You were doing well until you sneaked the link in there ;)
