Just had Electrolux insight 60cm cooker EKC6046K delivered after heavy deliberation between gas and elec but full time worker and can't do with cleaning gas hob + wanted closed door grilling and am too skint for dual fuel cooker purchase - The cooker is still in packaging but to send back costs £20 so kind of stuck with now but this is situation :- thought i had a dedicated wire running to fuse box from kitchen, only to discover when electrician came round today that what i thought was it, was a regular 13 amp double socket externally mounted to another double socket above work top. Elec guy said at first he could route a new connection under floor boards to fuse box for £100 (couple hours work) This is up from £25 for straight up connection if I had had an existing suitable cable running from kitch to fuse box. This seemed fair enough but it got worse. (My house is 100 years old by the way). He said the fuse box is about 20 years old and although wiring looked o.k and wasn't a fire risk that we didn't have an RCD board or something and no breaker before the fuse box and he found an earth cable loose unconnected to earth that he says is the elec providers responsibilty to connect via a spike into ground below house. He said though that it is a low priority thing for providers and could be anything up to a year before they fixed it but he could put a spike in and properly earth it, update the fuse box with a test button thingy and run cable through to cooker + install it for £300 as he said its a days work. He sounded like he knew what he was on about and is out the yellow pages + didn't charge to come quote us. He also will provide all relevant certificates of work done obviously and can be round next week. He didn't say I desperately needed fuse box sorting but that it was dodgy to connect outdoor appliances to mains as it stood without earth and if any metal touched a live wire when changing a light fitting it could be shock city. Also in out fuse box we have 6 plug/switch things all required by different elements of the house and he said there wasn't one free for an elec cooker so it would need adding but not sure if that is within £300 quote. Does anyone think this is a resonable price to charge for this amount of work. He spoke alot of jargon and mentioned alot of british standards etc so it was hard to remember everything he said but he did say that if my provider could earth this cable that it would reduce the cost by him to £150 ish to sort fuse box and connect cooker. Please help cos i'm a first time buyer and have never needed an electricain before!!?
