I'm building a garage which will have a PVC coated box-profile steel roof on top of wooden trusses. The ceiling of the garage will be insulated with 150mm mineral wool, then vapour barrier and 2 layers of 12.5mm plasterboard. The idea is to keep noise down as much as possible so I can tinker away inside and the kids can use it as a playroom. Internal stud walls are also going up for the same reason.
Does this setup leave me with a warm or a cold garage roof?
Do I need the non-drip fleece lining on the inside of the steel roof sheets?
TIA!
M
TIA!
M
