- Joined
- 29 May 2024
- Messages
- 5
- Reaction score
- 2
- Country
Looking for some advice about drinking water to kitchen extension. We are having a water softener installed in our garage and this will be used everywhere other than to supply the kitchen sink for drinking water. A new pipe has been installed which bypasses the filter. All fine I think but I am concerned about the route that the plumber has used. Its probably around 15 metres from the garage and I am concerned about the water getting warmed. I thing water regs state that any warming above 20 degrees should be avoided due to legionella risk amongst other things.
About 8 meters is through ceiling right next to (within 30mm) the main flow from the boiler to a newly installed under floor heating system. To make it worse, the cold pipe is 30mm above the heating pipe - and heat rises of course. The plumber says he's going to lag the cold water pipe but I am concerned that the hot water will be flowing 24x7 and we won't be drawing cold water all the time. Won't the cold water sitting in the pipe inevitably heat up quite considerably over a few hours?
The last 3 metres to the position of the new sink (not yet installed) is under the screed floor next to the hot water pipe which is supplying the sink. The floor also has underfloor heating pipes installed but these are perhaps 400-500mm away from the cold water drinking feed. Again some wamring seems inevitable but I suppose when the cold water tap is run, the contents of the last 3 metres or so will run through quite quickly.
I am minded to insist that the pipe is rerouted so its not close to the flow/return for the underfloor heating AND its behind the cabinets above the warmed screed slab AND its lagged even though further away form anything warm/hot. Pipes (other than under the screed floor) are still accessible, no plasterboard on walls or ceiling (yet) so now is the time to deal with it rather than wait and test and find the water runs very warm when walls/ceilings are plastered and flooring down kitchen installed and be concerend for years about how much bacterial is building up in the pipe.
I think the response I will get is that lagging the cold water pipe will be adequate even though very close to other hot pipes and last few metres through screed not an issue. Will lagging in this scenario be enough or should I insist on rerouting? Would it be reasonable to take the stance that the route is unacceptable and it should have been installed away form other heat sources in the first place? Other routes are available with a bit of extra hassle - seems to me that following the underfloor heating pipe route was easiest so that was what was done.
Thanks in advance for any advice
