hi, I have just installed 90mm of insulation between the rafters and am about to put 70mm on the underside of them, I am unsure as to what is the best way of fixing this tightly to the rafters?
notnochippy has already installed 90mm insulation and with tri iso 10 will come up to regs and MAYBE if u got spelling correct i might take u more seriously
Nobody will take a poster with 19 posts under his belt seriously, if you knew anything about it you'd also have let the OP know you need a 25mm air gap each side of it for it to comply too you muppet and its spelt TRISO SUPER 10 BTW!
freddy you only need a 25mm air gap under the triso between it and the plaster board and the usual 50mm above the 90mm that nochippy has installed. sorry, only the low posts but we all got to start somewhere
