Hi
I have a gravity fed hot water cylinder. The cold cistern is in the loft and has a 22mm pipe serving the cylinder.
I have warm water in the loft cistern and its discharging from the overflow!!
I think I might know whats wrong but I would be grateful of some advice!
I have recently installed a new mixer tap shower unit. The cold supply is direct mains fed, the hot is gravity fed. I have installed a single impellar pump to boost the hot system and fed this and the cold mains through a presssure equalisation valve just before the mixer tap. One of these: http://www.plumbworld.co.uk/-230
What I think may be happening is that the mains cold pressure is pushing back down the hot supply via the eq. valve. This in turn is pushing hot water back to the cyliner and back up the supply pipe into the cistern.
Does this sound probable and if it is, what on earth do I do about it???
The mixer tap is not thermostatic which is why I put in the equalisation valve. It all seemed to work fine....
Is there a problem with the eq. valve in that it should act as a none return/check valve to the supply with the lowest pressure?
Is there some sort of additional none return/check valve I can fit to the hot supply just after the pump but before the eq valve? Something like this http://www.plumbworld.co.uk/344-1881
Or is the eq. valve just not for this purpose???
I seem to have spent hours under the bath and thought I had it sorted.
Any help would be very gratefully received.
Many thanks.
Many thanks.
