Warmaline adhesive
1 Apr 2009
Gwynedd
Hi
I have just covered a wall with Warmaline, using the warmaline adhesive, i intend to paper the wall to finish it, i have 2 questions.
1. Do i need to use a lining paper between the warmaline and the finishing wallpaper.
2. when I apply the paper direct on o the warmaline do I need to use the same adhesive or will solvite suffice for this.
Any advice much appreciated as I have not used this stuff before and the instructions with it are vague.
PS is it possible to use Warmaline on top of a lining paper?
Andrew
Definately line it..two reasons, one, finish paper struggles to get a good grip on the surface of the warmline and two, the surface is vert soft, lining paper will help make it stronger and a bit more resistant to pressure marks from fingers etc
