After much debate research and general messing about I've decided to bin gas and go for an oil boiler. My local and friendly gas man has recommended a Warmflow Boiler. What I've read about them so far has been positive, however I have a couple of questions which I be greatful if you could give me some pointer on...
1. We're going to stick this boiler in our garage - not the outside warmflow boiler, but we're having it outside if you like. Does this reduce the efficiency of the boiler significantly - water temp dropping as it passes from our garage to the house (approx 50ft)?
2. Our mains water pressure is ok, but our shower is not as powerful as we'd like. We have a Victorian Terrace. 2 bed, 2 attic rooms, no En Suites, an extra WC, but nothing really out of the ordinary. We currently have an old Saunier Duval Thelia Combi.
Our man said we had a few options:
leave it as it was but replacing some of the pipework - 15mm changed to 22mm - which may up the flow a bit;
re-install a gravity flow type affair; or
install a Megaflow system which would sort it out, but cost a few extra quid.
Any suggestions - would a megaflow system be worth circa £1K extra?
3. We're also getting a reasonably sized extension and would like to use underfloor heating, but would like to be able to zone the heating - well isolate the living area from the rest of the house. As this is new pipework anyway (basically the extension), would this mean this makes it easier to zone off?
I realise this might be difficult to answer without actually seeing what's going on, but any help would be greatly appreciated.
Thanks very much.
Ant
Thanks very much.
Ant
