Hi Guys.
First post so be gentle.
I have a Warmflow 70/90 Whitebird oil boiler. Over the last few weeks it has been temperamental on both CH and HW. Yesterday morning it was dead. After a bit of poking about yesterday I discovered the dual stat (part no WDS3) had tripped, reset it and everything worked fine (240V in and out) and boiler fired up. However the stat is now tripping out after it has been running for a while so suspect it may be on the way out. Date of boiler is 2004 so perhaps not a major surprise. Is this a safe assumption?
One question though, why a dual stat? Is one probe for the adjustable dial setting and one a fixed setting in case the other fails? I assume it is to protect the boiler itself from overheating.
Lastly, on fire up there is a noticeable 'clank' from the top of the boiler. Have had a quick look but nothing obvious is loose - any ideas?
Thanks in advance.
Thanks in advance.
