I have an outside housed warmflow oil burner which over the past few weeks has developed a loud whining noise when it runs.
I recently got the oil burner serviced and the oil pump replaced which worked fine for a couple of months.
The burner has not been in use for the past 4 months or so but since firing it up the last couple of weeks it has developed a loud shrieking noise.
I did notice that after the pump was installed the burner made a few false starts and went into lock out mode but after hitting reset it fires up and ran ok. It maybe does this lock out 1 in 15 startups.
FYI - The oil has never ran out and when it runs it heats water and rads as normal albeit sounding like im stamping on cats!
