warning: Dewalt flip and radial arm saws
14 Sep 2013
Fife
If you have one of these take notice.
On the flip over be very careful of where the cables enter the grip on the machine.
They always break which can be a costly rewire. Bulk this point up with silicone or pvc tape. Don't store or move with this point on the ground.
Radial arm saw owners: Take the panel of on the right hand side to expose the belt. 3 screws. You will see the belt.
Take damp wood as chunky as possible and cut watching for any belt slip.
There is a screw (hex bolt on the back of the housing. You need to unscrew tge motor screws slightly and adjust tge rear screw.
Reason: Belts are fitted too tight and destroy the motor bearings.
So release the tension a little. Ensuring the belt wont slip... Ensuring the life of the saw..:)
