Morning.
I made some bi-fold internal wardrobe doors, 4 of them in total, 380mm wide and about 7ft tall. I made them from 18mm MDF, and added an inch and a half or so timber frame to each one, for depth and for visual, using planed timber from B&Q that was out in the yard (not sure it was treated). I glued and recess screwed the frames in place.
I brought them in from my garage overnight, in the morning though they had all warped - I look at them from the side as they are all resting upright against a wall, and there is quite a big curve to them from top to bottom - side profile is like an arc!!
So basically I cannot use them as is - is it the timber frame that has caused this? I suspect it is. I took them back out to the garage and stacked them onto a couple of A frames and put a load of weight in the middle to try and straighten them - absolutely no joy. Presume there is no way of heat treating in some sort of clamp to straighten them is there? New frame? Start again? Firewood time?
Any advice appreciated - thanks.
