I am building an extension with solid oak window boards. Prior to plastering I oiled the boards (hoping to seal them), nailed the underside to provide a key and then bedded them onto mortar.
However, the boards have all warped to varying degrees with a couple resembling ash trays!
My questions are:
1.As I have a further 4 boards to fit, what should I do differently to try to prevent warping when I install these
2.The fitted boards have warped such that on the top side, both front and rear edges are raised producing a dip in the centre along the entire length of the board (although it is worse in the middle).
I intend to remove some of the warp in situ by "planing" the rear edge of the board. However, due to the proximity of the window frame to the warped area, I can't get my electric planer close enough to the edge to use and a manual planer is proving to be very hard work! Can anyone suggest an easier method/tool to use or do I just have to persevere with the manual planer?
My questions are:
