Note: I've searched @ the existing threads on this forum, plus google, but couldn't find a final answer or solution, so asking for help. If you know of an existing source of info that resolves this problem, please feel free to simply link it. Thank you.
Hi all,
I have 2 large and tall patio upvc windows frames which are roughly 20 years old, possibly a little less, and which will be replaced in the next 2 years or so. In the meantime, they are extremely drafty and I would like to DIY fix them without spending too much money.
These are, on the left, a semi fixed frame which we open only sporadically in the summer with a sort of square key that came with the window, and a standard patio door type thing on the right that we open often as our main access to the garden, as you can see in the video.
The issues as I see it (please see video below for clarify):
- Very cold and draughty room in winter, feels like the doors are open even when it's all shut
- Left hand side frame is out of plumb or twisted in its casement, creating a large 15mm+ gap where air is coming through
- Both left and right hand side frame have large gaps, again between 8mm and 15mm+ which are causing draughts
The solution, as I've engineered it so far, but probably not ideal:
- Sealant or Gripfill type solution in the fixed left hand side casement to retain the frame in place
- Expanding draught proof tape in the "opening" side of the window, both right and left frames
Issue is I'm not sure if Gripfill will ruin the window material, or if the tape will work at all, hence this thread. Hope you can provide a little more advice or clarity if you've done a similar project or fix before and advice on best course of action.
Hi all,
