Was my Duofix frame made on a Friday afternoon?
28 Feb 2010
Derbyshire
Just come to install my 112cm high Geberit frame for my wall hung toilet and discovered its not exactly square.
The central welded section which the threaded rods for the bowl screw into isn't square in the frame. To get that level, I have to make the frame's uprights go out of plumb left to right by 5mm over their height. Is that normal?
I'm a bit miffed because the stud framing I've constructed in exactly plumb and these frames aren't cheap.
Regarding the threaded rods, how much out of level could I get way without being noticed if I want to plumb up the frame a bit?
