I have just prepared for the installation of a wash basin for the bathroom.
The basin has a mixer tap and from the mixer taps i have connected a popup rod for the plug hole and 2 copper pipes. (Hot and Cold feed).
Following instructions it says i can now connect up copper pipes to water supply. However these copper pipes i would say are 10mm whereas water supply pipework is 15mm.
Am i right in saying i need a 15mm to 10mm reducer. Just making certain this is right as i dont want to mess it up. Also will the reduction in size affect the pressure of water coming through a 15mm pipe as obviously alot more water is travelling through only to be held back by a 10mm pipe. Apologies if im being stupid here, just making sure everything is spot on
