washbasin noise
8 Mar 2009
Yorkshire
hi.. my bathroom washbasin has started making a gurgeling noise even when there is no water draining away. i have stipped the washbasin trap and that is clear, i have checked the waste pipe for blockages and that is clear. the water drain away from the washbasin and bath ok.
an ideas ?
cheers
mickcoulson
Gurgling noise is classic for air/venting difficulties. FWIW, a 1.5" AAV from screwfix, cut into the trap arm (ie. between the u-bend and the wall) will often "solve" such difficulties.
The root "cause" might be the layout of the waste and soil pipes esp if the waste runs back on itself in the wall or in the floor.
the trap is a bottle trap will that make any difference ?
No. But you can buy bottle traps with built-in anti-vac features - easy way to go.
if i fill the washbasin up and pull th plug the water drains away and no gurgling, but if i just run a tap thats when i get the gurgling noise.
I dont understand why running the taps would drain differently from pulling the plug? Does your basin have an overflow, and is it clear? I'd still think it would be the layout of the waste pipes. Perhaps get someone to flush the WC while you run the taps and then drain the bowl - listen for results.
