We've moved into a new place which came with an integrated Smeg washer/dryer. After first struggling to find the power switch for it (its on a socket under the sink thats attached to the cabinate carcase) it then sprang into life.
When doing a washing cycle it works fine.
When doing a drying cycle it works for 15 minutes or so and then trips the switch in the consumer unit... I'm very basic with dealing with these things so apologies for not using the right terminology but its not tripping the "Kitchen Ring" switch but is tripping the one next to it which has a switch and test button (guess this is the RCD?) - this kills both the kitchen ring and the mains rings (and triggers the burgler alarm) but leaves the lighing etc on. Switching it back on and it almost immediately trips again. Turning the Kitchen Ring off and then switching the other switch back on and everythings fine.
Is it likely a fault with the dryer, the electrics or the consumer unit?
