Washer walks after reconnected after move
31 Aug 2005
Recently moved, reconnected Kenmore front load washer after move, at spin cycle it "walks", actually vibrates violently. The movers talked about a moving kit. What is that and what do I need to do to remove it? If that isn't the cause, any other ideas?
its usually some sort of bracket that stops the "guts" from moving during transportation.
thing is, if you dont know what one is, who fitted it you your m/c?
it may also be m/c is not level,
loose weights
it may even be something else, i suggest you check with manual, if you haven got one call maker / check website
Your right breezer, usually a couple of brackets that fix the drum to the casing. If you run the machine with these in place it will eventually break.
Talked about it ? what did they say ? if they fitted one, remove it (but then again, why didn't they remove it !).
