Hi
My first post here.
Edit: I'm having a problem with my washing machine filling my sink up when it empties. It only fills just over the plug hole, then drains a few seconds later very quickly.
I'm having the same problem as above. I previously had a trap looking like a 'W' with the first hole used for washing machine drain, second for sink drain, and third connected to waste pipe. I replaced the 'W' for a u-bend trap with spigot for washing machine, but now when the machine empties it fills the sink a little, then drains straight away (so I guess it's to do with the water pressure, not a blockage). Previously the 'W' connection had a 6 inch piece of pipe connecting it to the sink, so it was low down, but when I replaced it I got rid of the six inch piece as the u-bend has a three inch bit that the spigot is on. Would that make the spigot too close to the sink?
How do I go about fitting a stand pipe? Can I connect it to the current waste pipe? I can't access my waste from the outside since as far as I'm aware, it goes into the wall and (possibly) joins next door's drain in a gully or something...
My first post here.
