Hi
I need to plumb in the drainage for a washing machine and dish washer. Problem is that they are integrated units and there isn't enough room at the back for the waste pipes.
There is a small 'cutout' of about 200mm high at the bottom of the back of the appliances for such pipes, but the outlet to my drain is higher than this. (about 250mm)
I am considering putting the hoses from each machine through my wall and emptying directly into the outside drain. I would essentially push the hose all the way through the waste pipe which only goes thru' the wall (and down to empty in the drain), up to about 25mm from the end.
What I would like to know is this - would this method drain ok or not? Is the height of the end of the hose an issue when draining like this? Are there likely to be any other considerations?
Thanks in anticipation of your help,
Paul
MOD
moved as posted in wrong forum
Paul
MOD
