Washing m/c sometimes not filling.
24 May 2016
Samsung WW7K5 fills with water on the 15/30 minute wash cycle but displays 4C error code (low/no water) on longer wash cycles.
Are there different inlet valves for different cycles and can an adjustment be made for low water pressure.
Thanks.
Many thanks for the link. I wil check the inlet pressure from the pump and the filter is clear but I am baffled why it works on a short cycle but fails to fill on a longer cycle.
Maybe the water usage is lower, so not enough time to trigger the fault?
