I have a Hotpoint WMA 76P that doesn't turn. It fills, seems to start to go through the cycle (without turning) then empties and resets after a few minutes. To date I have checked the water inlets and outlets which both work fine (no blockage in the outlet filter). Removed the motor and checked the thermal cut out (iaw another thread), I have connectivity between each brush lead and a separate pin on the connector and approx 3-4 ohms across the brushes so believe the motor is ok. Anyone know of any other tests I should be attempting (or have a circuit diagram of the machine). Any help gratefully accepted.
