Washing machine door problem!
13 May 2010
Hello. I have a hotpoint washing machine and i have a problem that i think it is from the door! First the washing machine turn off by her own then start working but only sometimes. Then i changed the door sensor (i think that´s the name) and the machine was working fine but after some days it made a Boom and the door light from the machine it is always blinking! I took out the cover and saw this;
http://yfrog.com/5ldsc00721nj
Can i do something to fix it or have to buy another one?
Thanks.
Motor brushes need replacing then u can solder the tracks on the pcb
go to you tube and type in hotpoint brushes shows how to do it
Just one question, if i solder first just to see if is really the door problem do you think it will work or do i have to change the bushes as well?
NO just change brushes first. otherwise it will cause more damage to pcb
